QUOTE(perrin1097 @ Jul 29 2009, 12:03 AM)
QUOTE(saigon71 @ Jul 28 2009, 06:18 PM)
Looking for an operational thermo-time switch for a 1974 2.0 (part number 311 906 161 C) that triggers the cold start injector during cold weather. Testing does not seem bad according to the following link:
http://members.rennlist.com/pbanders/djetp...tm#troubleshootThanks
Check Samba, The same seller has a germen supply neart canada and has or at least sold nos 2.0 injectors at same site, and i believe is listing a vacummn hose rubber thing for the 1.7 also nos.. I bought an NOS THERMO_ TIME SWITCHone and same seller has about 6 of same part different #'s, I ran the #'s and they are all close.. for example one is active at 32 degrees, another at 15 degrees, and the 3rd. fires the injector at 5 degress so the numbers are not really that important and even if your in the snow areas you should get some firing..
Appreicate the info Perrin. Is this the guy you were referring to:
http://www.thesamba.com/vw/classifieds/detail.php?id=410364Also, where did you find the listing of the temperatures for each part number...IE one is active at 32 degrees, etc. I would like to know which one I am getting - it gets pretty cold here sometimes. Thanks. Bob
