QUOTE(jsayre914 @ Jul 30 2009, 03:43 PM)
the round clamps fasten with a nut, and hold the large rubber washer on the injector
There should also be a smaller washer on the end of the injector.
If your hose came off the injector, I would suggest 2 things:
1. Get metric FI hose... if I remember correctly, the 914 uses 7mm fuel hose, and 5/16" is just about 8mm so it will probably leak.
2. Get proper FI clamps rather than worm type clamps.
