QUOTE(perrin1097 @ Aug 3 2009, 10:13 PM)
QUOTE(SUNAB914 @ Aug 3 2009, 06:30 PM)
It can be powercoated any color you wish. I did it.
I am anodizing or plating in the chrome and my other emblem the euro goes with this is NOS and already done./. any flaws and scratches with be seen, but your right powder coating fills in the whatever is under the rough paint.. etc. I just wanted a used one that was not monkey'ed with untouched and faded off they are fine but when home jobe removal and repaint is involved it is usually done to the acceptability of the doer, and I can tell by the paint job that was low priority,.. but thanks for the input.
Keep in mind that any metal badge will have to be cleaned to bare metal before re-anodizing the badge. So anything painted would need to be stripped off first - whether painting or anodizing it.
At the same time minor scratches & flaws could probably be burnished off if they're not too deep (not filler - even if painting), similar to what they do when restoring the alloy wheels.
Ergo, you want to see the base condition for your restoration of the badge & the black painted one above makes it hard to tell - especially since it's brush painted!
That begs the question - why did that person not just dip the badge in the paint as they did OE - or why not spray paint it, as both give a smoother & truer finish than even the best brush-work, and why he did not smooth out the scratches & dings before painting with 1000-1500-2000 grit wet-dry??
What year is your 2.0L 914?
...and is it USA or Euro or other/world spec/sale?
If you're trying to do the "true-to-form" high quality resto on your 914 & these badges, as it sounds, then you'll need to tie down whether the OE rear badges on your car were originally anodized black, painted, plastic or vinyl.
The plating which you mentioned would only apply to gold (anodized), and that was only used on the 1970-72 MY 914s & there were no 2.0's then - just 914-6's with a 2L 6 cyl.). None were chrome plated, although the engine lid "PORSCHE" letters changed from gold anodized to chrome plated in 73 MY (later to chrome-plastic 75-76 & part of 74 MYs I think).
By 1973 MY - when the 2.0 first appeared, they'd switched to black anodized, then to black painted (74 MY), then black plastic (75 MY), then black vinyl stick-ons for 76 MY (as I noted in a prior post).
I'm confused as to what you're trying to do with these vis-a-vis whatever your MY 914 is & whether or not a 2.0 or conversion or???????
