QUOTE(RJMII @ Aug 3 2009, 06:31 PM)
QUOTE(ghuff @ Aug 3 2009, 06:54 PM)
You are tuning your megasquirt setup with no knock sensor, correct?
Si, Ja, Hai... yup, yes. uh huh.
What have you tuned, and how'd you do it? I know YOU've tuned stuff.
Let's hear some experiences.
Man. It's really different depending on what you are working with. Starting out with a turbo motor is hard as well.
Not having a knock sensor means you will have to use your eyes, ears and nose literally.
Well the nose is excluded if you have a wideband.....
I'll post more in this thread when I get home tonight. I'm a little busy at work before leaving
Step 1, wastegate 100% shut. Your megasquirt calculations and map creation for fuel is going to be "ok" to get it idling perhaps if you are lucky.
Are you doing MS for fuel and timing or just fuel?
