I needed another bulkhead harness strap so I gave this a try. It fits tight as hell and is a quick, cheap and easy replacement. I used yellow to highlight photo and in the hopes I could piss someone off. It looks as if you would need something to pass thru the loop of the tie (on the backside) but as you can see it pulls up tight. I can't show the backside because I can only load one picture per post for some reason. Second time tonight!!!!
