VaccaRabite
Aug 5 2009, 05:14 PM
Cam is a Raby 9530
Engine is a 2056
Deckheight is .040
Dizzy is a mallory, and I am using a bosch blue coil.
induction is through dual IDF44
At what engine RPM should I set my timing, and how much advance do I want to use? I know I don't want to do it at idle, but I don't know at what RPM I should target.
Thanks!
Zach
JoeSharp
Aug 5 2009, 05:22 PM
You want full advance Zack. I do it at about 3500 RPM and 32* just to be sure.
aircooledtechguy
Aug 5 2009, 05:46 PM
For years the standard with a Mallory w/ gray/gray springs has been 12* @ idle and 28*@ 3K. Jake will probably chime in with different numbers now that I've posted those.
r_towle
Aug 5 2009, 05:52 PM
Zach, 3k rpms at 28 degrees is safe...any more and you may end to advanced.
You dont want to have detonation.
At 3k-3500 the distributor (any distributor) is at full advance. This is the best place to know for sure what the timing will be at full advance.
Rich
VaccaRabite
Aug 5 2009, 06:45 PM
Rock.
Thanks guys.
Zach
