QUOTE(JOE M @ Aug 5 2009, 09:05 PM)
I sort of get it but when I came across this picture it looked like the bottom part directly under the push rod tube actually goes into the tube on 1 rocker and sort of sits just below the tube on the other. I started to put the rockers back in today and stoped because I was unsure. I`m this close and dont want some stupid thing like this to completely screw me up. By the way Rich, do I need a running 914 to go to Connecticut or can I show up in a Jag? LOL.
914 pussy boy. No Jag...you have plenty of time. Get it together.
Put the rockers on just barely...then slip the spring in.
The spring goes under the pushrods and into the slots on the bottom of the spacers. that is the fun part...
Once you get it in all the slots, AND under all the push rods...slide it home...the part that goes into the tubes will go where it goes...
the purpose...so you get it....it to hold the push rod tubes in place and not let them vibrate into the head and allow you to loose all your oil from the case.
the tubes need to move (expansion and contraction issues) so the spring holds them in place at the head....and the movement is at the case...
Rich
