QUOTE(BRAVE_HELIOS @ Jan 28 2010, 03:36 PM)
QUOTE(perrin1097 @ Aug 6 2009, 02:45 PM)
second the rubber pads, i got 3 small sheets of thick durable Orange Rubber form the hardware store .. perfect.. the old ones will rust your tank.. saw it in my "gargared 12 years car" replaced the tank and threw out the '70's...\
the picture above is correct but the single one closer to the cabin side is to go partially over the curve not just on top of it.. mostly on top 1/3 over the hump/curve .. that was how my factory ones were when I pulled my tank.. you do not want any metal to metal..
I went to Home Depot and two other hardware stores, No one has ever heard of "Orange Rubber". So, instead I purchased a 4 ft long section of rubber base board molding. It's about 0.116" thick (a little more than 1/16" thick).
Can anyone confirm that rubber pads cut to the right dimensions and 0.116" thick will work? I am aware that the carpet pads are thicker. Perhaps rubber cemmenting 2 pads together would be a better match to the thickness of the original pads. BTW, great pictures of where these pads go!
hieght of the pad should not matter unitl it is so thick your gas tank sits so high your trunk won't close..
, proctection and vibration other than metal to metal. Oh by the way I apologize for "orange rubber" it is "orange" color and "ruber" material, actaully is a thick gasket material by the roll or by the sheet.. but what you have is fine, that is just what i found..
