First off I've been having this rich running condition ever sense I bought the car so i finely got around to dropping $40 for a MightyVac. The vac showed the following measurements:
0in = 2.00H
15in = 1.26H
4in = 1.78
Using pbanders calibration method these numbers don't match up at all, so then i looked up the Bosch p/n and it says "0280100007" which doesn't match the p/n listed in his article. I don't believe this unit is supposed to be on the car and work with the ECU correctly. Am I correct? If so whats the best course of action to get a replacement unit? Thank you
