QUOTE(martinef1963 @ Aug 12 2009, 06:51 AM)
Sorry bout that, I accidently posted this in the WTB/FS section.
I'll be starting a fuel system restoration this coming Sep/Oct and am gathering the necessary parts to get this done.
I will be pulling the gas tank and treating it with Por15 Fuel Restoration and seeing that the tank will be removed I might as well change the factory plastic fuel line(s) as well.
I've read that there is only one fuel line necessary for a carb set up. If this is true and I eliminate one fuel line, does it matter which one? From/to the tank?
Any help would be appreciated.
Fern
You will need:
New fuel pump
new regulator (if your pump is not pre-regulated for carbs)
new fuel filters (2)
1 hose from tank to fuel filter
1 hose from filter to pump/regulator.
1 hose from pump to center tunnel
replace plastic center tunnel lines with one made from Stainless Steel. Only need one.
Hose from tunnel line to another filter
hose from 2nd filter to fuel safe T intersection (if going dual carbs)
hose going from T to each carb.
No return line is needed as fuel pressure is only 3 or 4 pounds - not enough to overpower the carb floats.
Zach
