QUOTE(blitZ @ Aug 19 2009, 02:20 PM)
What else can be causing this?
What does your engine harness look like?
I needed 3 spare harnesses to make one good one for my 1.7L. The wires get brittle, especially just inside the thick plastic shielding.
I had to cut the thick plastic back about 1"-2" only to find a whole bunch of cracked wires.
Also, check all your injector/brain grounds at the large ground connector block under the plenum.
Lastly, plug wires and plugs. Get a ohm meter and measure each wire. Check the plug connectors. Check the plugs.
Andy
