I am installing a 3.2 into my '74 914 and it originally came with A/C. The A/C hasn't worked for years and is taking up room in the front trunk. I figure it is time to either remove it or make it do something. Problem with removing it is there is a large hole under it.
The condenser core is 20" wide, 10" long and 2" thick, but stands 2.5" tall with the mounting bracket. I was thinking of replacing it with an oil cooler of about the same size. Any suggestions on a cooler. I was hoping to use an off the shelf size if it is out there. I was planning on using AN-12 fittings.
Some shots:
The Box. The bar is the spare tire mount.
Inside. The thing in front of the condenser is a fan.
Underneath
