car show was great! one of the nices karman ghia's out there! a real cool burn out show, one 572c.i. elcamino was sumptin'
back to reality
QUOTE(Spoke @ Aug 15 2009, 06:33 AM)
also added in is a 60A or greater fuse for short circuit protection from the battery. Modern cars have a fusible link to protect from shorts from the battery. This can be the type used in high power audio units. This is totally optional but given how much people tinker with their 914s, probably not a bad idea.
i have a hand full of replacement fusable links, but i'm not sure of there amp. value. they are the "green" as i recall for a g.m. so i would imagine they are high amp. i also have a large inline 30 or 40 amp fuse. i understand the fusable link works slightly different, kind of like a slow blow. i'm thinking a 30 or 40 amp fuse would be good as i wouldn't think more than 30 amp's (charge or discharge) will ever go thru the 10 gauge wires. sound right?
A tight connection to the existing wires is mandatory here since this is the source of all power to the vehicle when operating.
check... i'll run 2 10 guage (ampmeter) 2 14ga. (1 for voltmeter and 1 to power trunk release future wire). it would be nice just to take power to the volt ga. from the hot side of ammeter (right next to each other)... do you think there can be that much voltage drop by tying in at the console end?
The relay is mounted in the interior so it should be easy to wire up. The relay is needed else the voltmeter will be directly connected to the battery and will discharge the battery when the vehicle is turned off. The relay can be of a very small type that carries 1 amp or so.
like a small fog light relay? i know there are "constant duty" soliniods for big draw/constant use... i guess the relay would hold up for a key on constant use?
here's the console gauge plate thats in the works right now.
air/fuel is going to use the ammeter and the arangement will be different.
Click to view attachmentClick to view attachment
