Rear Light Bulbs Numbered Outside to Inside, 4 Being the Backup Light
1234 4321
Front Marker is A
Front Turn/Flasher is B
______Flashers On_______________
Front Left A & B only Nothing on Right side front
Rear Left 2 Right 2
_________________________
Ignition Switch OFF or ON with head light switch pulled full out:
Front Left A & B only. Nothing on Right Side Front
Rear Left 1 & 3, Right Side Nothing
Brake Pedal Depressed Switch OFF Nothing:
Brake Pedal Depressed Switch ON:
Left 3 & Right 3
________________
No Turn Signals on Any Corner
________________
Bulbs Replaced and contacts - grounds sanded cleaned at each bulb
Pulled Hazard Switch in and out a dozed times per Haynes
New Fuse Set per Specs
Interior light and Trunk light work just right
License Plate Lights work just right
Hi/Lo beams work just right
What else do you need to know?
Thanks Bill
