QUOTE(YksKrad @ Aug 22 2009, 12:16 PM)
QUOTE(Elliot Cannon @ Aug 22 2009, 11:58 AM)
I use the pressure recommended by the car manufacturer. I use what's in the owners manual, not what's on the tire.
Agreed, in absence of the manufacturer recommended inflate till you get proper tread contact... Over inflating them to the max pressure makes for a rougher ride and wears the tires faster, in my experience...
I cannot believe the numbers of people registered as online now have not come to your tires rescue.
The auto manufacturers recommended pressure should only be followed if you have the original size and type of tire recommended by the manufacturer.
You should use the pressures listed on the side of the tire. The use of the tire at max pressure is only recommended if the maximum weight is expected to be put on the tire.
It is more often than not, suitable to run your tires at a slightly reduced pressure from max to avoid a rough ride and excessive tire wear. You will wish to toy with pressures to find a comfortable medium between you, your tires and your driving habits.
