QUOTE(ejm @ Aug 25 2009, 02:26 AM)
QUOTE(greenie @ Aug 24 2009, 09:07 PM)
, everything sounds fine except the pump runs continuously ( not the 1.5 seconds that it should).....I can pull the key completely out and the engine still runs.
How did you shut the engine off? The pump running for 1.5 seconds is controlled by the ecu not by the switch. Sounds like the problem is something else.
I turned the key numerous times,wiggled it around and I then could get the pump to run correctly.
The key could be pulled out from the # 2 switch position , this is why I think the tumblrs are bad also.
I stuck a small screwdriver in the lock last night and heard a little "tink" spring sound , after this the key could not be pulled from # 2 position.
I popped the clutch to kill it.
