914four
Aug 28 2009, 09:07 PM
No luck with the search function about this and I just have a quick question. Are the center console gauge lights supposed to dim when you dim the dash lights?
Dave_Darling
Aug 28 2009, 09:42 PM
I think they do in 73s, I know they do not in 74s. I assume that the 75-76 is the same as the 74 in this respect.
--DD
Larry.Hubby
Aug 28 2009, 10:12 PM
Dave is correct. According to the wiring diagram in the factory repair manual, the console lights are supposed to dim, along with the instrument lights in the dash, in the '73, but not the later, cars. Of course, these wiring diagrams also show that the headlights aren't supposed to pop up until the headlight switch is pulled out to the second notch on the '70-'72 cars, and, as those of with these early cars can attest, they pop up at the first notch, not the second.
orange914
Aug 29 2009, 01:32 PM
sorry for the high jack, but
i'll be adding console lights on my 73' soon. can anyone tell me if i should i take power from the light switch and the color wire to grab?
now back to your regularly schedualed program
gasman
Aug 29 2009, 02:46 PM
You should have all the connections to add the console right there in the harness by the heat lever. Go to the Pelican Tech section and they have what the wire codes for each gauge are and the lights for the gauges.......
lotus_65
Aug 29 2009, 02:50 PM
my '74 doesn't, but i wouldn't want the oil pressure or cht gauges to be out of sight...
BarberDave
Aug 30 2009, 05:07 AM
This is a small Hyjack !!!
I added LED bulbs to all my interior lights, console and dash, great
improvement in brightness! Dave
