I'm sure these have been discussed before, but I could not find the threads.
Two questions have come up recently through Pelican, each having to do with new parts that are now listed as the replacement for old parts. Specifically, the headlight switch, the hazard/flasher relay, and the 1.8's double relay.
I believe the older headlight switch has fewer terminals than the later ones. (No, I'm not sure where the changeover is.) The early ones are NLA, or were a little while ago, so the later ones are listed as the "appropriate" replacement. Does anyone know which wires to connect from the older wiring harness to the newer switch?
Second, the hazard relay ("flasher relay") has been NLA for a while that I know of. There is a newer one that has, I think, an extra pin on it. How do you wire the replacement relay to work correctly?
Finally, we had an issue not long ago where a replacement dual relay had the wrong number of pins on it. Someone here mentioned a similar problem, and that they had re-wired the relay (??), but no details. Does anyone know how that is done?
Thanks!
--DD
