QUOTE(tag @ Aug 30 2009, 08:39 AM)
QUOTE(Cap'n Krusty @ Aug 30 2009, 08:37 AM)
Sounds like the plate is stuck. Remove the vacuum unit, remove the breaker plate, clean and lube the plate, put it all back together the way it was, and try it.
The Cap'n
Okay
I'll try it now
I was hooking the Vac up wrong (wrong nipple on the diaphragm). So I guess my backfire at a steady rpm without load isn't caused by the vacuum advance. Under load the engine doesn't backfire.
