914rrr
Sep 4 2009, 12:10 PM
This is the last of our parts! We found a tub at the back of our storage that had more 914 parts! So we will be adding parts as we go through the tub.
We can provide photos upon request. Email us at 914rrr@comcast.net.
Most prices are negotiable, especially if you buy multiple items. If you want to pay by paypal, please add 3% to the sales price.
Thanks!
Rob
865-463-2575
MPS 041/051E: Tested / works: $25
MPS 049/051E: Tested / works: $25
Accelerator Cable (NEW): $20
Caliper Kit (NEW - not sure if front or rear): $15
Clock (center console): $10
Bumper Dog Bones w/bolts (set of 4) very nice cond: $20
Seal outer door to window pair (NEW): $20
Early Tach: $25
Fresh Air Fan Grills w/ seals (2) - seals are in great shape: $20 for all
Heater ext tube with flapper box: $10
Heater ext tubes (pair): $15
J tubes (pair) 1 is missing top tab: $15
Jack straps A (pair) - excellent condition. no tears in the rubber: $40
Jack straps B (pair) - rubber is excellent. metal base is corroded: $30
Odometer reset cable: $10
Rain tray funnels w/tubes and seals (pair)- I may have 3 or 3 pairs: $30 per pair
Shift rod boot (late) for firewall end. Very pliable: $25
Trunk targa top holders rear rubber (pair) w/bolts - used but no cracks: $25
Turn signal light seals (pair): $10
NOS Vacuum elbows for FI: $5 each. I have several.
Visor mounts - set: $20. I have 3 or 4 sets.
OEM Alloy wheel cap. Very good to excellent condition. used: $25
OEM Window cranks w/mounting washer and bolts (pair): $15
Rear suspension shims (1) 2mm, (2) 3mm, (1) 4mm, and (1 pair) 3mm mounting flanges: $5 each or make offer for the lot
Pair of Gray Injector Boots. used but in great condition: $20 for the pair
Engine plug set. Set of covers, inspection plugs, etc.: $20 for all
Relays: $25 for all
Dash switches: $40 for all
Engine plastic parts: $20 for all
nuts bolts assortment: $15 for all
Interior trim plugs: $15 for all
Lug nut covers - Qty 16: $12 for all
Star lug bolts qty 16: $40 for all
Star lug bolt qty 5: $2.50 each
Lug bolts (steel wheels) Qty 11 plus 1 oddball: $7
Alloy lugs full set OEM A: $50 for the set
Alloy lugs full set OEM B: $50 for the set
Alloy lugs full set OEM C: $50 for the set
Alloy lugs OEM qty 3: $3 each
Interior mirror (late) very good condition: $30
Rear trunk locks (2) some pitting on both: 1 with key, 1 w/o key and back lever missing: $40 for both.
Bra very good cond: $30
Auxillary Oil Cooler w/ sandwich adaptor, Aeroquip lines and fittings - exc cond. removed from my low mileage 914 turbo show car. easy screw on installation: $70
Door handles and ignition lock set with keys. drivers handle in good cond, pass side is broken. some pitting.: $35
Rear trunk latches (set - I have two sets): $20 per set
Targa top holders, white plastic, pair: $10
Clutch cable pulley, machined aluminum (not plastic) with bushing: $20
Shift linkage with front coupler, rod, rear coupler, rear boot, and cover. Coupler and front boot are in exc cond, rear boot is dry and cover has a crack: $100 obo for the group
SS heater box ext tubes (pair): $50
Air deflector plate - early - drivers side: $10
S tubes (pair with clamps - 2 pairs): $40 per pair
J tubes (pair) good cond, all tabs intact: $25 obo
orange914
Sep 5 2009, 01:42 PM
just a pat on the back for supplying so many 914 parts. sad to see the source go. thanks to the other suppliers also.
it's part of the reason the 914's are on the road in a big way
mike
914rrr
Sep 5 2009, 05:21 PM
QUOTE(orange914 @ Sep 5 2009, 03:42 PM)
mike
Thanks for the nice words Mike!
914rrr
Sep 11 2009, 10:08 AM
Some items are back up for sale!
zymurgist
Sep 11 2009, 12:43 PM
I might want the dash switches... does this include the headlight switch? If so, how many terminals?
Also, do you know what type of wheel the center cap fits?
914rrr
Sep 11 2009, 03:02 PM
QUOTE(zymurgist @ Sep 11 2009, 02:43 PM)
It does include the headlight switch. It has 11 terminals.
Center wheel caps fits all OEM 914 alloy wheels.
Click to view attachmentClick to view attachment
zymurgist
Sep 11 2009, 03:38 PM
I'll take them! What's your preferred payment method?
914rrr
Sep 11 2009, 05:14 PM
QUOTE(zymurgist @ Sep 11 2009, 05:38 PM)
sending PM.
Thanks!
Gigamight
Sep 13 2009, 10:23 AM
"Engine Plastic Parts", can you help me out with that one and let me know what all is included in that? I will be doing some work on a 1.7 and might as well get anything I might need to get ready.
914rrr
Sep 13 2009, 10:26 AM
QUOTE(Gigamight @ Sep 13 2009, 12:23 PM)
Hi,
Attached is a photo. I will see if Rob can give me an idea of what is included.
Thanks!
Gigamight
Sep 13 2009, 12:33 PM
QUOTE(914rrr @ Sep 13 2009, 12:26 PM)
Hi,
Thanks!
Click to view attachment I am printing out a copy of your pic and taking it with me today to compare with what is on my engine so I can see if you have much in that bunch that I need. Thanks for the pic.
7TPorsh
Sep 15 2009, 01:03 PM
Interested in the SS heater boxes. Can you post a pic and what would shipping be to 91367/ Thanks
914rrr
Sep 15 2009, 02:01 PM
QUOTE(7TPorsh @ Sep 15 2009, 03:03 PM)
We have SS ext tubes that attach to the heater boxes and the heater flaps. Pic attached. Will clean up nicely.
etcmss
Sep 22 2009, 06:14 PM
Looking for a really good bra for a 74---got one? picture would also help--headlight cutouts or roll up flaps? full or partial.
PM sent
914rrr
Sep 22 2009, 06:44 PM
QUOTE(etcmss @ Sep 22 2009, 08:14 PM)
PM sent
Send me an email at 914rrr@comcast.net. I can send larger photos that way.
Thanks!
