QUOTE(993inNC @ Sep 5 2009, 08:48 PM)
I've never driven my 914
(bought and now tearing down to restore), but I had that problem on my 993. After the 3rd time being roadside stuck (once on track twice on the street) I decided to "locktight" my CV bolts and thus far no issues. Hope to not have to take them out any time soon though
Big difference here between the 993 and the 914 CV joints. The 993 CVs have a plate over the end that captures the grease, so it doesn't get in the bolt threads when assembling. The 914 has an open CV joint that uses the flange on the transmission and a gasket to retain the grease. You try to locktite a 914 CV bolt, and the locktite ends up mixed with grease, and doesn't work worth a damn.
There are people who safety wire the CV bolts. That is a great idea, but I believe if you use the proper NEW schnorr washers, and the proper torque on the bolts, they will stay in. Since I started doing that, I have not had one back out. But I still check them EVERY time I put either 914 on the lift.
I used to use longer bolts, and put jamb nuts on the backside of the drive flange. Yes, there is room, and they don't require drilling the heads of the bolts.
