QUOTE(brandomc @ Sep 16 2009, 06:12 PM)
So, it sounds like i shoud take the head off and inspect. Is that what you would reccomend? If i do that then do i need new gaskets, or are they reuseable? Sorry if these questions sound stupid, just new to air cooled motors.
What would need to be done to the engine to remove the gaskets and get everything to seal back up without them?
No, I'd recommend doing compression and leakdown testing on all cylinders, even if you have to do it cold because you can't start the engine right now. That will at least give you a ball park on what you have got. Compression testers are cheap at any FLAPS (Friendly Local Auto Parts Store). You can usually borrow a leak down tester from Autozone or Advance, and rent them sometimes from Napa. You need a source of compressed air though.
Once done, report back on your findings. be sure to note is the testing was done on a warm or cold engine. Be sure that the throttle is wide open when doing compression testing. If possible, run the engine on a pallet or test stand to get it warm. if not, do it cold (your numbers will be a little lower).
If you remove the heads, be VERY CAREFUL to keep each lifter and pushrod together. They need to go back into the same bore they came out of.
Even if you are or are not using head gaskets, you want the tops of each cylinder to be as close to the same height as possible. You can test this by measureing deck height, and adding shims to the bottom of the cylinder to even it out. You want all 4 the same, or as close as you can possibly get.
Go to Amazon and get John Muirs book
How to Keep Your AirCooled Vw Alive, and the Haynes Tech Manual for the 914.
Zach
