police interceptor... nobody seems to want it... however, it has LT1 5.7L in it. It's rated just under 300hp as I recall.
So... uh.... will it fit?
zymurgist
Sep 18 2009, 09:44 AM
It's a small block Chevy, so probably. I do remember hearing a conversation at the ECC about LT1's with their reverse flow cooling etc. so I'm not 100 percent sure.
Bruce Hinds
Sep 18 2009, 10:00 AM
The reverse flow cooling would actually be an advantage! It will surely fit! Actually most anything will fit. There is a guy in Colorado that has a 455 olds or buick in his. B
SLITS
Sep 18 2009, 10:35 AM
LT1 = cast iron block, aluminum heads of early style ports ... no gain except for the loss of 25 - 50 lbs of weight.
'94-'96 is the pin drive, reverse flow water pump .. big ass dude.
zymurgist
Sep 19 2009, 07:47 AM
You want the Corvette or Camaro LT1 to get the aluminum heads. The Impala / Buick Roadmaster / Cadillac Fleetwood LT1's came with iron heads.
BarberDave
Sep 19 2009, 03:36 PM
Thats like asking " How far is up" Hell as big as you can do, ever seen Rick's
" Alein " . Small block or big block or sick block , If you can engineer it safely
it can be done. Go to it and supprise us!!!! Dave
