x6in6flames6x
Sep 18 2009, 02:35 PM
is the easiest way the get to the lines underneath through that tiny hole behind the plate? or to pull the gas tank?
ericread
Sep 18 2009, 02:46 PM
I'm a big guy with big hands, so the only way I even try to get to the fuel lines is to pull the tank. The good news is that I can pull a fuel tank in about 20 minutes now.
Eric
Sep 18 2009, 03:02 PM
QUOTE(ericread @ Sep 18 2009, 12:46 PM)
Pulling the tank is pretty straight forward ...
If you make the new fuel lines about a foot long, you'll be able to pull up the tank without having to disconnect the lines first.
Much easier that way!
Andy
bdstone914
Sep 18 2009, 03:04 PM
I pulled 2 Gas tanks yesterday, each took 15-20 mins by myself in the hot cali sun. Its alot easier to work with the tank out. Also, that access hole is a favorite spot for black widows, both cars yesterday had more then right under the tank when I pulled them. It could be the seals on the bottom of the tanks, or your old fabric hoses need to be replaced. When replacing them try not to make them too long as they will want to kink when putting the tank back in. 12 -14 inches is a perfect length. If you get it most of the way out and it seems like its caught on something, that would be the fuel tank level sender wires stopping the tank.
x6in6flames6x
Sep 18 2009, 03:34 PM
awesome, thanks guys. found the leak already just needed to know the best plan of action.
luckly we dont have many black widows in the PNW.
again, thanks for the input!
76-914
Sep 18 2009, 07:18 PM
I can do one in 20 min's...............Now! That first one took a taddddd longer.
