andys
Mar 12 2004, 12:45 PM
Has anyone (Brad?) ever cut a trailing arm apart? I'm wondering if there are any additional structural elements inside, or are they basically two U sections welded together to form a rectangular cross section, and hollow inside. I'm not talking about the pivot point/bushing or the bearing/hub areas, but the section between them.
Thanks,
Andy
Mueller
Mar 12 2004, 12:47 PM
it's built up sorta like a corragated card board box...it is not 100% hollow inside
Mar 12 2004, 12:48 PM
What's Inside?
rust?
Jeffs9146
Mar 12 2004, 06:54 PM
I have a bent one if someone wants to cut it open and see!!
Jeff
ChrisFoley
Mar 17 2004, 10:01 AM
Nothing is inside a trailing arm.
I cut this one open with my plasma cutter yesterday to show you.
This one had the box reinforcement on it, thus the extra thickness on one side.
agentblr
Mar 17 2004, 10:12 AM
I think my rear arm have corn flakes inside them? at least it sounds like when you shake them,this is bad
jonwatts
Mar 17 2004, 10:17 AM
Uh Chris, was there something wrong with that trailing arm? Cutting up a reinforced trailing arm for demonstration purposes only would be mighty big of you.
Andy was right, there is something inside, rust.
majkos
Mar 17 2004, 10:30 AM
Why the chop?
"Don't worry be Happy!"
It's St Patty day!
andys
Mar 17 2004, 11:54 AM
QUOTE(Racer Chris @ Mar 17 2004, 08:01 AM)
Racer Chris,
Thanks for the fantastic pic....just what I suspected, a simple rectangular section....no big deal. I know I'm pushing it, but what is the stock material (wall) thickness?
Andy
Mueller
Mar 17 2004, 11:59 AM
damn...then what the heck was I thinking of then???? I must be thinking (or not) of another car or part...thanks for making a liar out me
Mar 17 2004, 12:41 PM
QUOTE(Mueller @ Mar 17 2004, 09:59 AM)
you were thinking of the later model long in the area under the battery tray.
the later models have "rippled" reinforcements in there ...
Andy
Eric_Shea
Mar 17 2004, 08:06 PM
rust?
Looks like Andy had the answer all along...
ChrisFoley
Mar 18 2004, 06:58 AM
Actually that rust color is plasma cutting residue,which probably will wipe off.
The trailing arm was involved in a high speed impact and had no further usefulness on a car - perfect for an autopsy.
I can check the wall thickness today.
ChrisFoley
Mar 18 2004, 09:49 PM
I measured the metal thickness at .080" or 2mm.
andys
Mar 19 2004, 10:42 AM
Chris,
A BIG THANKS!!!
Andy
