Click to view attachmentClick to view attachmentClick to view attachmentQUOTE(naro914 @ Sep 20 2009, 12:12 PM)
I posted this on Pelican Parts back 9 months ago one day when World was down, so some of you may see overlap....
I need some help with Huey in getting it to handle right. I'm embarassed to say this, but in the past, I had my mechanic just put on what he thought was right. Worked great, but as time has gone on, I do a lot of the work myself so I really have no idea what was done in the past. ask me about anything on the car, and I'm good....except my suspension.
Anyway, we do not have stock 914 suspension: when we upgraded to 5 lug, I guess we put 911 stuff up front. 3.5" spacing for the caliper ears, (though we run 993 rear calipers on the front), and bilsteins. 22mm Welt adjust front sway, and I HAVE a Welt rear sway that is currently disconnected. Bilstein in the rear. 180# springs.
I am getting TERRIBLE understeer, never oversteer either with or without the rear sway connected. In fact on the track, were were getting the front inside wheel to lift, even getting a bit of that on an autocross. I'm thinking maybe the front sway is too stiff?
Basically, I have no bite in the front, it feels more like an old 911 that wants to just push through a corner.
I was told that I can't put 914 Koni adjustables on the car (someone on here has them for sale). Is that true? And based on what I have, what is the best suspension set up. for AX/Street use?
Thoughts?
Hi Naro914:
You have gotten a lot of helpful information and it may seem confusing which to use and which does not apply to your car. I hope I can help. My 914 is a V8 conversion which I drive on street and track, like you. I've working on the handling for some time and have learned some basics that apply to ALL 914s.
Spring Rates: I attached my Excel spreadsheet that calculates spring & swaybar rates and finally ends up with the WHEEL RATES...that's the number that matters. Why: given the spring mounting, the rear wheel rate is 117.38 times the spring rate.
With your numbers plugged in, you can see that your wheel rates are very close to the SAME front to rear. JPStein offered your same setup with 275 lb/in rear spring as something that worked for him. It is obvious that you need more rear rate relative to front spring rate.
MY SUGGESTION: Go FULL soft on the front bar and TEST the car. See how it feels. Then RE-ATTACH the rear bar. Now you have softened the front and stiffened the rear. Now TEST DRIVE the car. It should get better, make notes.
If you like the feel: Great. If it s not there, you can try disconnecting the front bar and TEST DRIVE the car. If you STILL have to much understeer, want a stiffer (more responsive) car, then it is time to go up in the rear spring rate.
I would suggest going up to 300 lb or more: Why? 1) extra in the rear rate will allow you balancing-adjustment with the front bar and 2) I found that 400 lb/in springs still gave a reasonable ride on the street. If you have 2" (NON-914) coil-overs SummitRacing.com and great prices on 10" springs.
SHOCKS: First off: buy a copy of Carroll Smith's DRIVE TO WIN!!!! It is the best thing I have ever seen on setting shocks!
I'm running Koni sport shocks in my 911 boge front struts and have found them to be very good. The control REBOUND only, but that is what helps the front get bite according to Carroll. If you can afford the cost, the Koni 6811 series struts shocks are Dual-Adjustable, but the best price I found was $314ea.
For the rear, I sent my old shocks to Koni and had dual-adjustable guts inserted.
I am vehement about JOUNCE/REBOUND adjustment in the rear as the JOUNCE control is what just got my car right!: stable & drivable. However, they were much more EXPENSIVE than the 6811 fronts. So if I were to do it again, I'd buy a Standard Product koni dual-adjustable shock. This would also get you into a standard 2" coil-over shock design with ride height adjustment.
Suspension settings: Since you are running radials on relatively soft springs, I would recommend -3 degrees all around. Before I made my car STIFF, I had perfect wear patterns across the Yokohama 245 fronts and 315 rears with -3 degrees. If your car is also a daily driver, you would probably have to back off the aggressive camber to -2 to -2.5 degrees. (I am currently at -2 with 450# rear springs) So camber HELPS.
Caster: stay with stock
Toe-in: THIS IS A BIG ISSUE FOR 914s. I did a big post about it on the thread: "Alignment specs for V8 DE 914". The short version I suggest 0 to 1/16" toe-in at the front. Racers run toe-out to aid turn-in, but again the trade off is that on the street ,with uneven payment, the car gets nervous....but not scary.
REAR-TOE: This is the big issue in that when the car rolls into a corner the LOADED wheels moves up and toe-in. I measured .200" toe-in GAIN for 2" of travel. At the same time the UN-LOADED wheel goes TOE-OUT at the same rate.
The clever Porsche engineers designed a rear suspension where BOTH wheels point into the corner and almost eliminates OVERSTEER. This was doubtless due to Ralph Nader and lawsuit worries. I have set my car at 1/16" toe-in per wheel and may go less. At Laguna Seca Historics, a Porsche specialist told me he sets 914s with TOE-OUT in the rear.
My Suggestion: With all the adjustments above to decrease understeer, BEFORE you spend $$ on rear springs, try setting your rear to toe-out at 1/16" per side and TEST DRIVE the car. If you like how it feels, try MORE toe-out. Keep in mind that you would have to go to .at least 200" toe-out to end up at 0-toe when loaded in a corner.
Ride Height: just looking at your car 's photo tells me the ride height is not a negative factor. 914s CANNOT be lowered much before screwing up the camber arc of the suspension. To truly lower a 914, racers and REMOUNTED the suspension UP in the car. I run my car at 5" at the sheet metal bumps at each corner of the underside of the chassis.
Corner weight: I used to use bath room scales to balance out my Formula Ford, but for a street car, it is 1)hard to do and 2) nearly impossible to achieve. That said, your car is fine.
I hope this give you some help on setting up your car. The only other suggestion is READ tech books on racecar suspension and setting.
Best,
Terry
