I have a 71 with the side shift trans. I bought a new fire wall bushing and a used rod that goes through it. I can put a .016 mm feeler gauge between them. I took this measurement in different places to make sure it is not the bar that’s worn. Is that the correct amount of play. That’s not a lot but I was thinking there should be none but it should just slide smoothly. Or did I get a badly made part from Pelican Parts? I did order the bushing made for the conversion.
