Completely Rebuilt to 1911cc's. Many New Parts ,including Heads, Rods, Oil Cooler, Bosch 009 Dist.,Crane Cam & Crane Lifters,Valve Springs & Rockers, HD Oil Pump & Booster, Mahle 96 mm P&C's. Standard Crank & Case all Machine work & balancing by Competition Engineering (Walt Watson). This is a long block with Newly Machined Flywheel inc. clutch & pressure plate. The cam selection was designed to be used with Weber 40IDF Carbs. Also Included is a pair of New Weber Manifolds with complete Linkage Package. The engine has been stored inside in a very dry environment without pushrods installed to insure valve train is keep in as new condition. Additional pictures on request. $1750 , Buyer pays shipping . Can be picked up if desired in Tiburon Ca, just 15 mi north of S.F.
Contact Max Handley
415 435 5299 PST ZIP 94920
