OK, for those who have been following my transmission thread, that's finally resolved. So I go for my test ride this afternoon, and my alternator doesn't bootstrap.
Background: There is a "bootstrap" process to the 914 alternators. Whereas new alternators have permanent magnets and begin creating energy immediately upon start, our 914 alternators do not start creating any significant voltage until the unit is "bootstrapped" by revving the engine to between 1500rpm to 2000rpm. Once this has been achieved, the magnets are energized and the alternator should work normally. Until the bootstrap has occurred, the generator really creates no significant voltage.
I had replaced my alternator with a used unit about 14 months ago. At that time I also replaced the voltage regulator with a new Bosch solid-state unit. And for the past 14 months, it has all worked exactly as expected.
As of today, the voltage gauge in my center console stays at about 10.5 volts. The battery voltage (pole to pole) shows 12.1 volts at rest, and after about a two mile test ride, it still showed 12.1 volts. I then started my car in the garage, reved the engine to about 2,500 RPM, and checked the battery pole voltage - still at 12.1 volts. I would expect to see 14 volts.
The only thing that has changed is that I have dropped and reinstalled the transmission several times. The ground strap is securely attached, and I have no difficulty in getting the engine to start. It is certainly a coincidence that my alternator problem is happening just as I re-install the transmission, and I don't believe in coincidences...
Any thoughts???
