I've got my motor out and I'm going through my wiring. Just trying to clean everything up and replace the shrink tubing where it's deteriorating.
I had my fuel pump hooked up to the coil before but found the stock wires for the pump so I'm planning on using them to wire it up.
While I was in there I came across a green and black wire with a broken connector on it. I looked in the book and the only green wire with a black stripe that I can find that would be in that area would be for the flashers (mine work fine).
I attatched a pic so you can get an idea for exactly where it is.
Anybody know what this wire is for and if I should re-connect it or not?
Thanks,
The car is a '73
