Excellent upper dash pad. No cracks,no broken mounting studs. There are 2 small dimples it the top area above gauges. $275.00 plus shipping.
Jerry
number6
Sep 27 2009, 06:40 PM
Hi Jerry. What year car did this come out of? If it's for an early car, I'm interested! Thank you.
Sending PM.
-duc
jmmotorsports
Sep 27 2009, 07:12 PM
QUOTE(number6 @ Sep 27 2009, 05:40 PM)
Sending PM.
-duc
I am not sure of the year. What are the differences ?
Jerry
number6
Sep 28 2009, 12:51 AM
Jerry, from Tech Tips 700:
"503. Two different molded dash top pads were fitted to 914s. The first for 70-71 models has a wider relief for the clearance of the longer glove box door. 72-76 dashes had less relief. Because of this, 72-76 dash pads cannot be fitted to 70-71 cars as the glove box door will bind when raised. Always check the dash pad before fitting. 70-71 glove boxes had an opening of 170 mm, 72-76 glove boxes had openings of 150 mm. Dash pad vinyl grains also differed with one factory intermediate variety not matching at all. BEWARE!"
jmmotorsports
Sep 28 2009, 08:20 AM
It is a late pad.
Jerry
number6
Sep 28 2009, 06:37 PM
Thanks, Jerry.
-duc
stophos
Sep 28 2009, 06:42 PM
PM Sent
lucky25
Sep 30 2009, 08:13 AM
PM sent Lucky25
jmmotorsports
Oct 7 2009, 10:12 AM
bump
