New to me car, 1991 mercedes 300te
I have the car 20min starts, drives, no problems. Park it.... 8 hrs later D E A D. I jump it, and it fights, but starts up. drive it one hour home, runs fine, just before i turn her off I try the electronic seat adjustment and the headlights dim off and the radio goes out as i touch the switch. i try the window button, i pull up on it as the window is already up, the lights go off again, interior stuff as well. So it seems the alternator right?
i park over night, today it is dead again, so i replace the battery with a new one. put the positive terminal to the battery, and the negative to a test light then to the battery, it glows like a becon. i pull all fuses one at a time and the test light does not go out.
so what could it be?
i am going back out on my lunch break to troubleshoot it again.
mabey it is a relay that grounded??? i have to find the relay board.
mabey an aftermarket radio/ alarm/ po rewire ???
mabey the alternator is grounded??? i have to find that too to check.
how to test the alternator, easy test. it is parked in baltimore, i dont want to walk home to PA tonight.
any more ideas??
the car is currently parked with the battery disconnected untill my lunch break.
Joseph
