URY914
Sep 30 2009, 08:23 AM
The daily driver has been on jackstands for the last month. I cleaned the engine/trans and it was spotless. After a few weeks I notice a spot on the floor under the trans. The rear linkage plastic cover has a drop on it ready to fall. I clean it off and loosen the clamp to remove the cover. I pull it down and HALF A QUART of trans fluid dumps out on the floor. Oh and burnt fluid smells sooooo good too.
So it would seem that I have a seal that is leaking at the linkage input shaft. Is there an easy way to fix this???
This is a side shift.
tradisrad
Sep 30 2009, 08:37 AM
YEP, replace the seal at the shift shaft. I did mine a year or two ago and it was not very difficult.
shift shaft seal on this page:
http://www.pelicanparts.com/catalog/shopca..._TRANSM_pg2.htm
URY914
Sep 30 2009, 08:39 AM
Perfect! You even provided a link.
Thank you
Cupomeat
Sep 30 2009, 08:45 AM
BTW, why was the transmission fluid in the side shift cover "burnt"?
This would concern me as there isn't any reason why it would overheat in the cover.
Unless, the fluid got so low in the transmission that it over heated and some of it leaked down as well.
URY914
Sep 30 2009, 08:52 AM
It smelled burnt probably because it was old and hadn't been changed for who knows how long. It was most likey burnt before it leaked into the cover.
Dr Evil
Sep 30 2009, 11:50 PM
I have these seals and can ship Thurs if you need. You need to drain the box and remove the console to fix it. OR, you can buy one on my rebuilt selector units and just swap it in. It comes with the cone screws and new shift bushing.
URY914
Oct 1 2009, 07:04 AM
Thanks Mike but I ordered the seal from Pelican last night and it'll be here Tuesday. I've already drained the rest of the fluid.
Dr Evil
Oct 1 2009, 11:34 AM
Right on. Did you order the O-ring that you will need to replace on the side that goes into the gear box as well? I have those too.
URY914
Oct 1 2009, 11:58 AM
O ring???
Nope didn't order it. Didn't know I needed to.
Dr Evil
Oct 1 2009, 12:06 PM
P/N 999-701-359-40
I can get you one out right now for $2 shipped
PM me your address.
URY914
Oct 1 2009, 12:26 PM
PM sent
tat2dphreak
Oct 1 2009, 12:53 PM
yep, I replaced the little one, and forgot the o-ring, and damned if the o-ring didn't start leaking afterwards.
Dr Evil
Oct 1 2009, 01:53 PM
Its in the mail
URY914
Oct 1 2009, 02:45 PM
Perfect, thanks!
URY914
Oct 1 2009, 05:47 PM
To remove the console it looks like I need to drive out that roll pin.
Correct???
Dr Evil
Oct 1 2009, 06:12 PM
Big negative good budy! You need to remove the shift linkage (did you order new cone screws?) and then just remove the 2 nuts holding it in place. Click on my rebuild link below for pics.
URY914
Oct 1 2009, 06:28 PM
I did remove the linkage. I don't in your thread how to drop the console out. Do I just put it in nutral and it comes out?
Dr Evil
Oct 1 2009, 07:15 PM
Yup. You need to wiggle it back and forth while pulling it out. You will get it.
URY914
Oct 1 2009, 07:34 PM
OK, got 'er out.
So the O ring is what is causing the leak and not the seal?
Dr Evil
Oct 1 2009, 07:39 PM
No, the shaft seal is leaking if your cover fills with oil. BUT, when you remove the console you need to replace the O-ring or it will leak.
URY914
Oct 1 2009, 07:42 PM
But to replace the seal I'll need to remove the roll pin and pull the shaft out.
tradisrad
Oct 1 2009, 07:51 PM
I vaguely remember replacing the o-ring. I dont recall having to drive out any roll pin either. Sorry I did not have as complete of an answer as the Dr. did, but I've only done it once...
URY914
Oct 1 2009, 08:03 PM
The Dr. is probably busy in an O.R. and can't reply right now.
URY914
Oct 1 2009, 08:27 PM
Dr Evil
Oct 1 2009, 08:32 PM
Yes, remove the INNER pin so that when you reinsert your rod it goes with the seal instead of against it.
URY914
Oct 1 2009, 08:54 PM
OK but this will have to wait till Sat. morning. Thanks for all your help.
BTW, is "reinsert your rod" a medical term?
maf914
Oct 2 2009, 12:30 PM
Paul,
Is that a bronze shift rod bushing in the console? If so, does it work okay? How is the fit on the shift rod? Snug or loose?
ericread
Oct 2 2009, 01:54 PM
QUOTE(maf914 @ Oct 2 2009, 11:30 AM)
Paul,
I have a bronze shift rod bushing. It's not totally snug, but I think it works better than the plastic bushings.
Eric Read
r_towle
Oct 2 2009, 02:24 PM
Paul,
When you are ready to get the roll pin out, support the forked piece very well so you dont stress out the aluminum console while banging.
Also, while its out and simple, flip the bronze bushing around...its gives you a bit more clearance for 5th gear...
Rich
URY914
Oct 2 2009, 02:31 PM
The bushing was installed by the previous owner. I didn't even know it wasn't plastic.
URY914
Oct 2 2009, 02:32 PM
QUOTE(r_towle @ Oct 2 2009, 01:24 PM)
Paul,
Rich
You mean put the flange on the inside of the console?
It is put in with JB Weld it look like.
r_towle
Oct 2 2009, 02:38 PM
Mine was all fine until I rebuilt and readjusted the shifter forks...then it hit.
If yours is in with JBWeld then leave it...
If you ever have a problem with getting into 5th...that is the issue to look at first..
It could be from the position of the engine/tranny....it could be the shifter adjustment up front...
Its really slight, but you just cant get all the way into fifth..the piece that attaches to the end of the shift rod hits that bushing...just a smidge.
Rich
URY914
Oct 3 2009, 07:02 PM
QUOTE(URY914 @ Oct 1 2009, 06:04 AM)
I got the seal in the mail today from Pelican. Three days early!! Who would have thunk it???
I should get o-ring on Monday.
URY914
Oct 3 2009, 07:06 PM
I drove the roll pin out this morning. I tapped it on one side than the other a few times to get it loose than drove it all the way out. Here are the parts laid out, w/o the O-ring.
The piece on the lower right is the piece that came out with the fluid. It can't be good.
Getting the old seal out was more of a pain than getting the pin out.
SlingShot
Oct 12 2009, 12:25 PM
Similar Problem I'm having on a 70 914-6. It has the same leak at the shift selector seal. I replaced the seal, and it still leaks. There is a gap between the brass bushing and seal, so I placed an O ring there and that helped the problem, but still leaks. The shaft has some play inside of the brass bushing, but I wouldn't consider it exsesive. Any thought would be appreciated. Thanks, Chris
