kenshapiro2002
Sep 30 2009, 11:01 AM
OK...I give up...on my pedal board, there's a plate riveted to the board that has a nut welded to the plate that sits directly under the gas pedal. There's no obvious explanation for the nut being there...nothing threads into it. Do I need to put up a photo or is this something normal that somebody can explain to me?
Geezer914
Sep 30 2009, 11:10 AM
Are you missing the pedal stop???
Sep 30 2009, 11:20 AM
QUOTE(Geezer914 @ Sep 30 2009, 09:10 AM)
There's a plastic stop that threads in there to make sure you don't stretch your accelerator cable.
I'm sure it's in the PET, you should really download the catalog ...
http://www.porsche.com/all/media/pdf/origi...914_KATALOG.pdf Andy
neil30076
Sep 30 2009, 11:21 AM
Yup, peddle stop. You need to have one or you will over stretch the throttle cable.
Sep 30 2009, 11:28 AM
Found it, Group 7
Item 51, Part# 901.551.671.20, Hexagon-Head Bolt
You give up too easy!
Andy
Cupomeat
Sep 30 2009, 11:36 AM
I'll see if I have an extra one I can send you tonight.
kenshapiro2002
Sep 30 2009, 11:55 AM
Bless your heart man. lemme know if you can't find it, and I'll go hunting. No freakin' winder I had the car up to 187 on the Mulsanne straight!!!
QUOTE(Cupomeat @ Sep 30 2009, 01:36 PM)
7TPorsh
Feb 16 2010, 12:41 PM
i need one of these too. What size is it? I would think this is an easy Home Depot fix?
VaccaRabite
Feb 16 2010, 02:31 PM
Your nuts are on your pedal board? You need a Nut Bra!
Zach
Feb 16 2010, 02:57 PM
QUOTE(Vacca Rabite @ Feb 16 2010, 12:31 PM)
Wouldn't that be a Nut-Case?
Cap'n Krusty
QUOTE(7TPorsh @ Feb 16 2010, 10:41 AM)
Home Depot is about as likely to have a metric plastic bolt as is Kragens or Pep Boys.
But maybe your HD has a bigger selection than mine ................
The Cap'n
7TPorsh
Feb 16 2010, 02:58 PM
hmmm...
type47
Feb 16 2010, 03:08 PM
While you're working in the pedal board area, might as well check that your clutch pedal stop is there too.
kenshapiro2002
Feb 16 2010, 03:09 PM
Why would it have to be plastic? Lighter weight for Auto X ?
QUOTE(Cap'n Krusty @ Feb 16 2010, 03:57 PM)
The Cap'n
Feb 16 2010, 03:15 PM
QUOTE(kenshapiro2002 @ Feb 16 2010, 01:09 PM)
Plastic doesn't rust ...
7TPorsh
Feb 16 2010, 03:19 PM
If the clutch stop is that metal bar thats bolted to the top end of the clutch opening...got it. I'm putting a new gas pedal in adjusting the cable, hex bar, etc.
Seems like these webers don't translate to very much pedal travel.
This little bolt should help adjust for max travel.
I'm sure any metric bolt will work; just what size?
kenshapiro2002
Feb 16 2010, 03:36 PM
Then sell your 914 and buy a Europa!
QUOTE(SirAndy @ Feb 16 2010, 04:15 PM)
