is there some sort of plug that is supposed to seal off the big hole in the 1.7 tin right before Cyl 3?
The spark plug type CHT sender I am using only needs a tiny hole, and I am sure I am loosing a ton of cooling air through that gaping hole.
Zach
Sleepin
Oct 5 2009, 10:09 AM
There is supposed to be a grommet in there IIRC Zach.
zymurgist
Oct 5 2009, 10:15 AM
Metal plug similar to what you might see in the rear bumper (appropriately sized of course)?
neil30076
Oct 5 2009, 10:29 AM
QUOTE(Vacca Rabite @ Oct 5 2009, 09:06 AM)
Zach
Zach, IIRC, the grommet that you use on the accelerator cable where it passes through the sheet metal fits exactly in there - at last thats what i used.
JFJ914
Oct 5 2009, 10:51 AM
It's P/N 021 119 553, but it is NLA from the dealer. It is a rubber disc. Check VW suppliers or AA. George probably has them.
Sleepin
Oct 5 2009, 11:39 AM
QUOTE(John Jentz @ Oct 5 2009, 10:51 AM)
Or just measure it and pick one up from Home Depot Racing!
