How To:converting rear shocks to adjust. coilovers, Boge shocks with stock dia springs |
Mueller |
Jun 20 2005, 11:50 AM
I decided to add threaded collars to my Boge rear shocks so that I could adjust the ride height (rear too high)
Normally, one buys Koni Yellows or Bilstiens and simply just slides the threaded collar w/adjusting nut over the shock and uses 2.5" diameter springs. Due to budget constraints, I opted to keep my Welt. 140 springs (would work with stock springs) and my Boge shocks which seem to function just fine. First step is to take the springs off, then the perch...on the Boges, the perch is held onto the shock by means of 3 formed protrusions on the shock body, I was able to just hit the perch with shock upside down to remove the perch. I then cut the perch to fit both the adjusting nut and the inside of the collar. After the modifications, the perch is now 2 pieces instead of 1. In order to get the smaller ID perch over the 3 protrusions, I cut a slot in it to be able to spread it apart so that I could move it lower on the shock body, I also made 3 holes in it for rosette welds to the shock. The pictures should be pretty self explanatory of before, during and after. I can now easily adjust the ride height....total cost was about $60 including shipping for the collars and adjusting nut. Attached image(s) |
Mueller |
Jun 20 2005, 11:51 AM
Attached image(s) |
Mueller |
Attached image(s) |
Mueller |
Jun 20 2005, 11:53 AM
here you can see the lip to hold the collar:
Attached image(s) |
Mueller |
finished shock, all painted and ready to install.
Attached image(s) |
SteveSr |
Jun 20 2005, 02:01 PM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
That's really cool Mike,but what happens to the shock when you weld on it?... (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) any concerns about the heat?
SteveSr |
Mueller |
Jun 20 2005, 02:05 PM
these shocks do not use the main housing tube for the piston, there is an internal tube for that, so unless one punches a hole in the tube or used way, way too much heat and welded 360° around the tube with the heat cranked up, I don't see a problem...... famous last words when I'm replacing my shocks in a few weeks, hahahahaha |
andys |
Jun 20 2005, 02:18 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
Mike,
Very ingeneous! Yeah, I too would've been concerned with the heat....guess it's ok?? Andy |
Mueller |
Jun 20 2005, 02:26 PM
I would have preferred TIG welding them, but no real option since I don't own one (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) nice and cheap option..it'll work until I decide to spend some "real" money (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) I think a clamp type device could also be made to work as well as long as it didn't slide down........ |
maf914 |
Jun 20 2005, 02:33 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
Not bad, Mike. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
But someone has to ask, so...Will welding the shock body void the Koni warranty? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Dr. Roger |
Jun 20 2005, 02:35 PM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
Mike,
You know i've got the MIG and stick welders.... Call me on your next strut conversion... k? I wanna' do mine also. What was your source for the adjuster nuts and collars?? |
Mueller |
Jun 20 2005, 02:39 PM
Roger, I have a MIG (gas) and oxy/acet. just no TIG (yet (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) ) Coleman Racing products*, there are a few different kits, mine are the 2.04" ID collars X 5" in length...the threaded collar can be opened up somewhat if the shock body is larger.....the Boges are much smaller so it worked out great............. *google it |
Rotary'14 |
Jun 20 2005, 03:18 PM
Senior Member Group: Members Posts: 753 Joined: 24-April 05 From: Los Angeles Member No.: 3,977 |
That looks great Mike,,
I was kicking around a similiar idea. In my research, I saw some of these on evil-bay,,, http://search.ebay.com/coil-over_W0QQfkrZ1QQfromZR8 Do you think these can be trusted not to fail? These are priced pretty cheaply. |
Mueller |
Jun 20 2005, 03:25 PM
i almost went with those dirt cheap units, but they couldn't tell me what the ID of the collars are and I didn't feel like hunting down the car they list them for to measure a shock/strut. the coleman racing units seem a better quality unit, I have 1 threaded collar with nut that i found at a pick-n-pull, looks just like the cheaper kits as seen on eBay...the fit is a little sloppier between the nut and the collar. |
Korijo |
Jun 21 2005, 07:11 PM
[]D o [] o []V[] o []D Group: Members Posts: 1,308 Joined: 16-July 03 From: North Bend, WA Member No.: 914 |
mike,
did the bottom gold piece come in your kit that you ordered? whats the proper name for that gold piece? |
URY914 |
Jun 21 2005, 07:19 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,708 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Where did you get the parts?
Or did you say where already? |
Mueller |
Jun 21 2005, 07:39 PM
Coleman Racing Products Dave, Adjusting nut??? |
TimT |
Jun 21 2005, 07:43 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
koni calls it a spring perch,
Im sure the good ole boys at Coleman call it something else (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) |
TravisNeff |
Jun 21 2005, 07:46 PM
914 Guru Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region |
Damn, $25 for the set? The coilover kits that come with springs (which are $60 a pair) go for $250. OOOhhh the CSOBSC hindsight in me...
Mueller |
Jun 21 2005, 07:51 PM
$25 each X 2 yea, but with the kit you bought, I'm sure it bolted right on....the Coleman kit even with the correct 2.5" dia. springs still needs some fabrication to the top spring perch according to them...I didn't use mine since I kept stock dia. springs so I do not know for sure.........also, I'm betting your kit came with Eibach springs which are top of the line or darn near close to it.....you didn't pay too much for what you got..... |
Lo-Fi Version | Time is now: 19th May 2024 - 07:56 PM |
