I've been doing a lot of busy work with the 914. In no particular order:
- Falken RT615, 205/50/15s arrived, and had them installed this evening
- Replaced left-rear brake caliper twice in the past two days (first replacement was bad)
- Removed old rear shocks and springs and replaced with Koni Sport Shocks and 185# springs
- Front sway bar is using 911 drop links, and are too long (thanks Brad!). Will replace with adjustable 914 drop lengths
- Car has a lot of over steer, will tighten up front sway bar
- Left headlight pushrod snapped yesterday, will replace with spare
- Need four locking bolts for rear Koni spring perches (emailed Koni)
- Found that the right-rear caliper was loose, tightened (that could have been bad)
- Checked and noticed the lack of bump-steer kit, will install my old one
- Inspected front wheel bearings, tightened front-left bearing
- Adjusted clutch cable
