Stuff I need to get rid off: Rust free front hood Rust free rear hood Stock left side door w/ all the window works removed Stock metal right side with the beam cut out, and window parts removed 2.0 (94mm) Cylinders which can be taken out to 96mm 2.0 long block-crank/cam/case (no heads) 1.7 Complete engine 1.7 case, open and hot tank cleaned 1.7 heads, ugly but will clean up nicely Headlight parts, motors, bits and pieces Rear window glass Stock starter Stock FI fuel pump Boxes of odds and ends Engine fan housing and sheet metal USED Long block w/ big valves heads, 1.7 counterweighted crank, 96mm NPR p/c Stock metal rocker panels Outside and inside door handles Single progessive weber carb
