Picture of my plugs from 4 & 3 respectively. I'm getting spark to the plug and when I switched 3 & 4's plugs still no difference with the plug wire pulled on 3, but 4 caused the idle to stumble. What are the chances 3's wire is not letting enough voltage through (slim I guess)? At least we know both plugs are good but I was hoping that was the problem. My next step is to change the wires, since we know it is getting fuel and from the looks of the plug it was getting spark at one time at least. So if that doesn't do it (and I don't think I'm that lucky), then time to check my valve adjustment? Attached thumbnail(s)
Not much of an update but at least I have some pictures of my new (to me) exhaust setup from Aaron. The engine build is moving along, I spoke with Mark over the weekend and the big delay is that the heads are still with the machinist. For now, we are looking at a June delivery date but that depends on when the heads come back. I got to use the media blasting cabinet over at Ron’s a couple of weeks ago and boy-howdy does that do a good job, much better than my power washer in the driveway (big mess). If you’re reading this, thanks again Ron! Attached thumbnail(s)
But I did manage to work a few things out and placed an order with Mark De Bernardi last weekend to build me one of Jake Raby’s 2056 engines! In preperation of the new engine, I bought Aaron’s ( That’s about it for now, I just wanted to put a stake in the ground
Finally finished the priming & painting of the front trunk Worked some more on the engine bay as well Today Attached thumbnail(s)
When I got home Today, I thought it must have been fricken Christmas. The first package was the CV gasket & rubber kit I bought off eBay. The second package was Mark Bland (aka Engman Attached thumbnail(s)
| 0 user(s) viewing
0 guest(s)
0 member(s) 0 anonymous member(s) |
