Day 2:
The saga continues with the suspension upgrade. Found I have a slightly bent A-arm It now looks like I will have to remove the master to clean up the rust here. Might as well do it while I'm in here. Right now the plan is to upgrade to turbo tie rods and clean up the suspension parts and replace the ball joints and bushings (possibly upgrade) Another while I'm in here item will be to install a front sway bar. The A-arms are ready so I just need to add the mounts and install. Attached thumbnail(s)
