I've come along a bit. Here' some photos of my jackpoints and patches. I used UPOL High Zinc Content weld Through Primer on all the metal pieces.. and am contemplating drilling a hole to fill them with point once grinding is finished. I ground down one and it looks awesome. Just needs a coat of hi build primer, seam sealed and painted. Nearly (for me at least) a perfect repair. As far as removing the whole jack point.. I ground the old ones back until I hit thick metal. At that point it was either cut the quarter panel and go the rest of the way or just patch it. Being So Cal I figured it will be along time before they will need to be done again if ever. So just patch work. Yet to jack it up on them. Attached thumbnail(s)
