update: it runs! there were two culprits. craig laughlin put me on the right track for the first one. he suggested that it might be a loose wire on the resistor pack. this turned out not to be the case, however while i was down there i took a good look at the double relay. sure enough, on one of the plugs there was a wire that had worked loose, just happened to be the thick red wire from the battery. this explains why some injectors were working intermittently. the spade was making random contact whenver the plug or wiring was jostled. and we did a lot of jostling. the other culprit was the oil filler neck. the filler cap on l-jet is supposed to have a gasket to help it seat properly. this gasket was missing on my car, so we went to the local hardware store and picked up a decent o-ring that will work until i find the correct part number. btw, anyone know the part # for this seal? gotta give props to jim chambers who drove over to my house from portland on several occasions to help me test a bunch of stuff. he checked the dwell and set the timing this afternoon after i got it running. also big thanks to craig laughlin for providing a new fuel pump and putting me on the trail of the injector problem. and thanks to all who gave me many suggestions on things to check. so after not being fired for 20 years, it runs! not super smooth yet, but we'll get there. now all i need is new tires, some body work, a new muffler, and... ~a
