914 14-pin..............................................911 14-pin to relay board.........................................from engine 1-ignition switch (yellow)........................1-ignition switch (yellow) 2-Alt. Light on dash (blue)......................11-alt. (blue) 5-oil warning light (green/red)................9-oil pressure switch (green/white) 914 #7-signal to tachometer (black/purple). I wired it directly to #C on cd ignition {yellow wire} from crane xr-700....) 914 #8-power for relays (power from fuse #9, signals ignition on, black) I routed this one to the front trunk where I've put in a relay board and fuse panelfor my (relocated) fuel pump, fog and driving lights. 911 #3-oil temp sender (green/black) wired to a wire that was separate from the 914 harness (green/black also, I think) that went to the oil temp guage on the appearance group harness. 911 #4-oil pressure sender (green/red) wired to a new wire I ran to the appearance group console. I wired 914 #3 and #4 directly to the reverse light switch, rather than use #5 and #6 on the 911 14-pin connection, since the PO had cut those off. Here are their colors/fuction: 3-reverse light switch (grey/brown) 5-reverse light switch (green/yellow) 4-reverse light switch (grey/brown) 6-reverse light switch (grey/brwn) I didn't use pins 9-14 on the 914, since I had an alternator with an internal regulator. Here's what they do: 9-heater blower switch (green/white) 10-ground for relay board (brown) 11-heater blower (green) 12-power from battery, no fuse (red) 13-fuel pump power (from relay on relay board, black-red) 14-power from battery (red) I also didn't use the following pins on the 911 14-pin harness: 2 (no wire), 7 (no wire), 8 (no wire), 10-realy to fuel pump, warm up regulator, aux air valve, thermo valve (red/white), 13-heter blower motor (yellow/black), or 14-B+ on alt. (red)
