Well, it runs again! It has been strange. Everyone said it had a vacuum leak. I agreed, but didn't know what was leaking. Than I thought about it. Three plugs showed an indication of running rich. One, #2, looked lean. I plugged all the vacuum lines as suggested, and then disconnected the cold start valve. It started right up and idled sort of for two or three minutes. Then it died. It restarted, but died again after a couple of seconds. All HE's were hot except #2. Need to look at that. Also, when it dies, it is hard to catch with the throttle. I wasn't cranking, so I don't know how it felt myself. I had the air flow sensor removed from the air cleaner, and flipped it over so I could watch it. It looks normal, opening a little as the car is cranked and most of the way as the throttle valve opens and the car accelerates. Now, on to the cylinder #2 problem, and the dying out. More reading to do, and deciding what to hook up again. A few more notes on this problem - 1. I have a decel valve, but I did not find it described in the fuel injection descriptions, nor was it on the drawings. However, when I disconnected it, I found a hard spot in the small vacuum line. It turned out to be a little "pill" in the line just before it is connected to the decel valve. This was a small metal thingie that blocked the vacuum line. ![]() I replaced this line. Sucking on the line indicated that a vacuum was pulled through this line and vacuum was held. The decel valve has been removed and plugged, but I may reconnect it later.
