I am getting very frustrated. I sent the injectors out for cleaning and testing, and installed them yesterday. Today, I tested it all out. I had a leak on the right side, I think I cracked the hose. I cut the end off and re-installed it. No leak for now, but I still need to repplace the right side hoses! When I tested it, it starte d quickly, but the problems remain. #2 is cold, and it won't idle. It falls right trough and stalls. Even when revved up, it will hold it for a few seconds and then just dies. I can save it , but it will "pop" through the intake system. I don't think there are any leaks in the vacuum system any more. The only possilbe one might be the throttle body itself. I hate to remove it though! Why is #2 not running? No idea at this point. Ichanged out the plug, changed the wire, nad may have changed the injector. The only thing I can think of is a bad wire to the injectors. I will clean everything tomorrow, including the connectors. The plug looks wet as if it is getting gas, but the pipe is cold!! I also checked the fuel pressure while it was running. No problem. I though it might be dropping and that was causing the dying of the engine.
