I thought I'd create a new list from Page 1. I have corrected so many that it will be easier to make a new list. 1. Wheel shake - the steering whell shakes at most speeds, but it does not do it all the time. Seems like some things need to sync up to create the shake. It did it before the new tires, and after, so I think it is something else. I suspect the re-drilled rotors (4 to 5 lug) that are at fault. I'll figure it out one day. 2. The headlights are dim, and not aimed properly. I need to get new lights! 3. I need instrument panel lights bulbs. 4. Need to work on the ventilation system, and maybe also fix the heater! 5. Need to find sun visor mounts. 6. Speedometer is not calibrated right due to the tire size change. Placeholder! 7. Odometer does not work. 8. Transmission problems - no 1st synchro, some grind in 2nd (shifter?) 9. Wiper motor does not park. Need to pull trunk to fix. 10. Need to clean all the fuses and holders! 11. Need a lot of body work. 12. Would like a front sway bar. Also need to pull the tank to install! 13. Need to install CHT, voltmeter, and power inverter. 14. The steering wheel has play inthe top bearing. This is the current list. I feel good that I have been able to fix so many things. There are still lot to do!
