I bought some cheap driving lights from Harbor Freight, just to try out. After studying the wiring diagrams, and the stuff on 914club, and figured I could do it! I removed the lower dash pad, the headlight switch, and tried to find all the wires. Finally, I found three wires, abut one was gray/red,and the diagram showed black/red. After studying it for a while, I decided that was the balck/red wire. I hooked it up and it worked! I could hear the relay clicking and everything! Now, I have to get the lights in place! I carefully cut out the rubber from the bumper, and removed the two 10 mm screws and could get at the mounts. I put the lights in and was able to tighten them down fairly well. The lights are not that stable, being all plastic! ANyway, I wired them in and they worked. I need to do a little work aiming them better, but I was really proud of myself! Now I need to get JWEST's flasher thingie, and also a new fuse panel. I think they may be the next thing to buy, if I get some money!! The fuses are a little old, and I don't like the German fuses anyway.
