Two Wheeled Type IV project pics. The project begins starting from the rear wheel and working forward! I'm building up a WIDE 240/50VR-16 tire /wheel combo, steel wheel powder coated black spoked to a Honda CB750 rear hub. It's custom but cheapo way to make a kickass rear wheel. I trued the wheeel with this computerized torque wrench I made with strain gages. ![]() ![]() ![]() ![]() Soon the engine/tranny will have a swingarm attached to it with custom wheel and tire! ![]() MAX WIDE Road Rubber - Metzler 240/50VR-16 arrived today (12-05-07)! Need to press in new rear wheel bearings then "muscle on the Metzler! I used my extra 914 Diamond Wheel Rim to hold the bike wheel during tire mounting, Note the plastic tubing I lined the rim with to protect the powder coat on the bike wheel.Made 2 custom tire irons to aid in tire mounting process.... need to make one more with a little longer lever..... a tire this size will take 2 guys and 3 irons! ![]() ![]() ![]() ![]() ![]() Mounted! ![]() ![]() Stock starter needs to be replaced with something a bit smaller! ![]() ![]() Cardboard mockup of the swingarm pivot structure Mild Carbon Steel swingarm pivot structure welded Here's the new protoyping stand for the mockup w/laser for alignment ![]() ![]() ![]() First CAD iteration of swingarm design ![]() Finished boxing in the swignarm! These pieces > ![]() ![]() Setup with Delorto's on one side-> ![]() First mockup using parts from an '83 Honda V45..... ![]() Latest Frame prototyping, Ninja ZX7 forks, 46 tooth rear sprocket, and 43 tooth front sproket mounted..... ![]() Initial airbag suspension fabrication.... ![]() ![]() Alternator and Chain Drive completed... ![]() ![]() foot clutch ![]() ![]() ![]() ![]() Attached thumbnail(s) ![]() ![]()
