Since the crankshaft and rods were in good working order - I've decided to build a 1911 motor. My parts list includes: Rebuilt 1.8 heads with 1.7 rocker arms 96mm AA jugs 96mm KB pistons Raby basic valve train kit with 9550 cam Gasket kit plus front/rear oil seals All new bearings New alternator (since I'm there) New MPS. Found a good deal and couldn't pass it up Machining: Clean case Clean, polish, magnaflux crank Re-surface, re-bush and balance rods (at least weigh and see where they are) Re-surface flywheel I'm taking a few things in next week so I'll update once all the stuff gets in.
