999.704.172.50 sealing ring 914:101-10 #24 qty:3 999.107.173.50 sealing ring 914:104-00 #2 qty:1 900.123.011.30 sealing ring A 22 x 27 for 900.136.013.02 union A 16 qty:1 oil bypass modification: http://forums.pelicanparts.com/911-engine-...ild-videos.html 911.107.008.01 oil pump 76-> PET 104-00 (911 1977) #(1) 911-911E/ springs, guide, plugs case, cam housings and cam towers taken to Allied Machine shop for cleaning $100 total engine management system http://www.clewett.com/index.php?main_page=index&cPath=2 youtube video SEXY! https://www.youtube.com/watch?v=FT-f9ov5ypQ&NR=1 11/13/14 dropped off case and 11 through bolts/washers/nuts 12/08/14 stopped by to see progress, none to date, still waiting 01/13/15 project on hold due to CABG surgery 02/20/15 stopped by to check on status, no progress, still waiting 03/24/15 Mulligan CABG 04/17/15 6106641 type 911/07 arrives 05/18/15 stopped by to check on case. It's being worked on. 06/07/15 thanks to Gary, Chris, Rod, mark, mark, rob, Jon, Pete, Porsche friends, music friends. Church friends. My family I love you barb Kate jame Kim precious grandchildren. 07/14/15 Not dead yet, ignore tone of 06/07/15 entry. Removed frequency valve block-off, reinstalled frequency valve "Four separate oil lines are required to connect the oil tank to the engine." http://www.pelicanparts.com/914/914-6_cons..._info_guide.htm http://www.914world.com/bbs2/index.php?showtopic=247015 2.2E p's & c's http://lnengineering.com/index.php/product...piston-set.html shift linkage solution, CV's http://www.tangerineracing.com/transmission.htm machine shop for crankshaft and rods https://www.facebook.com/pages/Burtonsville...154349891267211 Mar 10, 2015: 6106641 2.2T not including carbs, distributor, coil, wires. Includes fan and housing, engine shroud, flywheel clutch pressure plate assembly https://www.youtube.com/watch?v=l5GVA-RU4zQ engine startup at Tangerine Racing chain tensioner tech article: http://www.pelicanparts.com/techarticles/9...tensioners2.htm
https://www.youtube.com/watch?v=gRLyDnp7G_0 October 2013 https://www.youtube.com/watch?v=K_A7rPcvYCM August 2014
2L core engine, longblock, 1 ea 2L heads 2L short block, core, 3 ea 2L case 2L crankshafts 2L rods 9550 camshaft and matching lifters 94mm pistons and cylinders 96mm pistons and cylinders windage tray with seals flywheel D-Jet AAR, fuel pressure regulator, decel valve, cold start valves L-Jet AAR, fuel pressure regulator, decel valve, cold start throttle body D-Jet 2L intake manifolds, intake air distributors, air cleaners L-Jet 1.8L ntake manifolds, intake air distributors, air cleaners engine cooling tin 2L cooling fan housing +bus relay boards seats, black, 4 ea backpad, black, 73-> door panels black carpet, brown center tray w/cushion, brown x2 console combo gauge w/oil temp 73, 74, 74-76 oil temp sending unit/taco plate alternators starter D-Jet ECU D-Jet 2L fuel injectors, intake runners, intake air distributor, fuel rails MPS distributors, L-Jet & D-Jet L-Jet ECU L-Jet AFM D-Jet 1.7 fuel injectors, intake runners, intake air distributor D-Jet 1.7 oil bath air filter w/stand D-Jet 1.7 air filter elements, 4 ea transmissions 4 ea, 1 rebuilt side shift Dr Evil clinic front hood engine lid with letters, green IMSA front fiberglass bumper fiberglass front bumper GT fiberglass front valance for flaired fenders gas tank with expansion tank x2, +1 expansion tank stainless steel heat exchangers, 2L brake fluid reservoir front struts glass, door and vent, rear lighting, front. rear, turn, fog, housings and lenses heating system ducts aftermarket steering wheel x2 with mounting hubs 4 bolt Fuchs with lug bolts 5 bolt Fuchs 6x16 x4 1 pair with RA-1's for 911SC/Carrera 5 bolt Fuchs 7x16 x2 5 bolt Fuchs 6x15 with Hoosier slick 5 bolt Fuchs 6x15 x2 911SC front spoiler '69T 2.0L engine (see 6192376 blog) '70T 2.2L engine 6106641 914-6 oil cooler 914-6 engine sheet metal 914-6 oil tank Patrick oil tank 914-6 oil lines 914-6 throttle linkage kit 914-6 flywheels, clutch disc, pressure plate, throw out bearing cooling fans and alternators 911 engine shrouds; black, orange and red quick 6 engine mount bar 2.2 heads, set 2.2T pistons and cylinders, refurbished/honed carrera chain tensioner kit
4732902935 47229032454702909702 4762902802 4762903848 4712915231 4712905288 4752908028 4732923584 4742903753 4712935288 4742908267 4722910989Attached thumbnail(s) Attached image(s)
1 user(s) viewing
1 guest(s)
0 member(s) 0 anonymous member(s) Search My Blog
